RB2011 + hap ax3 - routing help needed
I have bought the new hap ax3 to replace the wifi AP in the living room, but the config proved to be more difficult than I 'd anticipated.
on
I have an ISP router I can’t stop using - VOIP + IPTV. I have a RB2011 connected to it in bridge mode, providing DHCP server to 192.168.1.0/24 on eth ports, and to 192.168.10.0/24 on wlan1, for IoT devices only.
I have a Linksys router in the living room and I wanted to change it to hap ax3. It currently links the devices there to the rest of the network.
What I’d like to achieve is to have the following setup:
I’ve tried to do it for a few times and simply failed. I was able to get devices behind hap ax3 to reach internet (but for some reason I cannot access other devices on the LAN - no ping, nothing).
If this is something easier and more managable with VLANs, I’m open to that too. I simply want to isolate IoT devices from the rest of the network and maybe free up some broadcast traffic. The WiFi will only be provided by hap ax3 (the rest of the routers will have wifi disabled).
I’m hoping this was clear.
Thanks a lot in advance!
Could you export the config of the hAP ax³ and post it here?
/export file=anynameyouwish (minus sensitive info)
hello!
thanks for your reply!
I was able to get LANs to work. I’m able to get an IP from the RB2011 and reach the internet and local network. 5GHz also works fine.
However, now, I’m unable to connect to 2ghz network - the one for IoT devices, and I can’t for the life of me figure out what’s wrong :frowning:
EDIT: weird.. now I can connect to the 2ghz network and get a local IP, but I can’t connect to the internet or local machines. I want this to have its own subnet and reach internet but not the other subnet.
# 2024-07-20 11:42:31 by RouterOS 7.15.2
# software id = 38FB-5HB4
# model = C53UiG+5HPaxD2HPaxD
add admin-mac=D4:01:C3:4E:96:7C auto-mac=no comment=defconf name=bridge
add name=bridge-iot
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
    configuration.country=Turkey .mode=ap .ssid=wifi5ghz disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi channel
add band=2ghz-n disabled=no frequency=2300-7300 name=channel1 width=\
    20/40mhz-eC
/interface wifi configuration
add channel.band=2ghz-n .frequency=2300-7300 .width=20/40mhz-eC country=\
    Turkey disabled=no mode=ap name=iot security.authentication-types=\
    wpa2-psk ssid=.wifi-iot-2ghz
/interface wifi
set [ find default-name=wifi2 ] channel=channel1 channel.skip-dfs-channels=\
    10min-cac configuration=iot configuration.country=Turkey .mode=ap .ssid=\
    .wifi-iot-2ghz disabled=no security.authentication-types=wpa2-psk .ft=yes \
    .ft-over-ds=yes
add configuration.mode=ap .ssid=test mac-address=D6:01:C3:4E:96:81 \
    master-interface=wifi2 name=wifi3
/iot lora servers
add address=eu.mikrotik.thethings.industries name=TTN-EU protocol=UDP
add address=us.mikrotik.thethings.industries name=TTN-US protocol=UDP
add address=eu1.cloud.thethings.industries name="TTS Cloud (eu1)" protocol=\
    UDP
add address=nam1.cloud.thethings.industries name="TTS Cloud (nam1)" protocol=\
    UDP
add address=au1.cloud.thethings.industries name="TTS Cloud (au1)" protocol=\
    UDP
add address=eu1.cloud.thethings.network name="TTN V3 (eu1)" protocol=UDP
add address=nam1.cloud.thethings.network name="TTN V3 (nam1)" protocol=UDP
add address=au1.cloud.thethings.network name="TTN V3 (au1)" protocol=UDP
add name=iot-pool ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool2 ranges=192.168.10.1-192.168.10.254
add name=rb2011-pool ranges=192.168.1.2-192.168.1.254
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" \
    disabled=yes disabled=yes name=zt1 port=9993
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge-iot comment=defconf interface=wifi2
add bridge=bridge interface=ether1
add interface=ether1 list=WAN
add interface=bridge-iot list=LAN
add address=192.168.10.1/24 interface=bridge-iot network=192.168.10.0
add address=192.168.1.17/24 interface=ether1 network=192.168.1.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address-pool=default-dhcp disabled=yes interface=bridge name=defconf
add interface=bridge name=server1 relay=192.168.1.16 server-address=\
    192.168.1.16
add address-pool=iot-pool interface=bridge-iot name=dhcp-iot
add address=192.168.1.0/24 dns-server=192.168.1.16 gateway=192.168.1.16 \
    netmask=24
add address=192.168.10.0/24 dns-server=192.168.1.17 gateway=192.168.1.17
    192.168.88.1
set allow-remote-requests=yes servers=192.168.1.1
/ip dns static
add address=192.168.10.1 comment=defconf name=router.lan
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    established,related,untracked
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface-list=WAN
# in/out-interface matcher not possible when interface (ether1) is slave - use master instead (bridge)
add action=masquerade chain=srcnat out-interface=ether1 out-interface-list=\
    WAN
add disabled=no dst-address=192.168.1.0/14 gateway=192.168.1.16 \
    routing-table=main suppress-hw-offload=no
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Istanbul
/system note
set show-at-login=no
/system ntp client
set enabled=yes mode=broadcast
/system ntp client servers
add address=tr.pool.ntp.org
add address="time.google.com "
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/system script
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :foreach iface in=[/interface/wifi find where (configuration.mode=\"a\
    p\" && disabled=no)] do={\r\
    \n     /interface/wifi wps-push-button \$iface;}\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
If we consider the default bridge as WAN and the IoT as LAN, change the default bridge to be part of the WAN interface list and remove out-interface=ether1 from the masquerade rule:
set [ find interface=bridge ] list=WAN
set [ find out-interface=ether1 ] out-interface=""
A default route would also be needed:
add dst-address=0.0.0.0/0 gateway=192.168.1.1
As for limiting access to the “WAN” network, a drop forward rule would do the trick:
add action=drop chain=forward dst-address=192.168.1.0/24 src-address=192.168.10.0/24
A side question - what is the purpose of the following route:
getting this on the last /set command: ambiguous value of interface, more than one possible value matches input
I was able to manually change it in Winbox.
> As for limiting access to the "WAN" network, a drop forward rule would do the trick:
> ```text
I did the rest as well.
I'm still not getting any internet access on iot wifi :frowning:
Posting new recent config in a new post for simplicity.
EDIT: answer to your side question: I was just trying to find a way to make it work really :frowning: thanks a lot!
# 2024-07-20 15:19:03 by RouterOS 7.15.2
add name=bridge-iot
/interface wifi
    configuration.country=Turkey .mode=ap .ssid=estapitipit2 disabled=no \
    20/40mhz-eC
    wpa2-psk ssid=estapitipiti2
/interface wifi
    estapitipiti2 disabled=no security.authentication-types=wpa2-psk .ft=yes \
    .ft-over-ds=yes
/iot lora servers
    UDP
    UDP
    UDP
    192.168.1.16
/zerotier
/disk settings
add comment=defconf interface=bridge list=WAN
/ip dhcp-client
    netmask=24
    192.168.88.1
/ip dns static
add action=accept chain=input disabled=yes dst-address=192.168.1.1 \
add action=drop chain=forward dst-address=192.168.1.0/24 src-address=\
    192.168.10.0/24
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
add disabled=yes distance=1 dst-address=192.168.10.0/24 gateway=192.168.1.16 \
    routing-table=main scope=30 suppress-hw-offload=no target-scope=10
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/system note
/system ntp client
/system script
    source="\r\
    \n "
/tool mac-server
fix your nat rules. srcnat without dst/src won’t work IMHO
thanks a lot for your reply.
can you be more specific as to what rule I should be adding?
Until you sort out your dual bridge issues, and more so the conflict of treating the bridge like a LAN functioning entity but also a WAN entity, I dont think much progress will be made!
Overall the config seems confused!
192.168.1.16
.0
I think the remedy is to be a bit clearer on the planning side.
You have an ISP router that you cannot replace due to internet + other things…
You do not need to use the ISP router for wifi.
You have the RB2011 getting a public IP (you stated bridge mode) for internet traffic or do mean it gets private IP on the ISP router LAN??
From the diagram it looks like the ISP router gives out a private LAN on 192.168.1.1, in which case, the RB2011 gets an IP address of 192.168.1.16 as its “WANIP” when looking from behind the router.
If so, then why do all the devices behind the MT have the same subnet as that of the ISP router???
That would imply the RB2011 is not doing any routing its just a switch???
You also have to decide on the wifi side of the house, how many SSIDs and thus subnets you need.
Do you want to separate guest wifi from home user subnet. Do you want to separate IOT equipment or media equipment on wifi from home users.
Normally we tend to say yes, for basic security principles.
hello anav! thank you for taking the time.
Yes, that’s all correct. RB2011 has a local IP (no public IP). I didn’t want to have a different subnet back in the day, and this seemed to work. Now I’d like to be in the same subnet for my eth connected LAN (everyday machines: media player, music streamer, NAS etc) in two separate rooms.
I’m also trying to get 5GHz network in the same subnet, but a separate subnet for 2GHz for IoT devices. I don’t need a guest wifi.
Yes, RB2011 is the DHCP server and it doesn’t do much.
two SSIDs - one for daily use 5GHz and one for IoT. I don’t need guest wifi as I don’t share my password.
would the following information be of any help?
Rb2011 also has an IP of 192.168.10.65
Ax3 also has an IP of 192.168.10.1
