RB2011 Interface Led
Hello!
Is it possible to disable the interface LEDs (1-10) on RB2011? If not, then this post is a feature request! :slight_smile:
Thank You!
Put some tape over leds.
:smiley:
Prefer software solutions :slight_smile:
NOt all can be done by software, often ethernet leds are controlled by switch/ethernet chip…
That makes me sad Panda :smiley: I hope in the future HW versions it will be supported feature.
