Rb2011 iperf
Use iperf today on 2 wireless N laptop connected on a rb2011, signal strength was -40db.
Results of iperf were 8mbits/s.
Doesnt seems ok, does it?
Tried to change the following, without success:
  • tx rates all the same
  • bridge on/off
  • channel
  • completely up to date
  • wpa2 aes
  • N only
  • 20mhz channels
    i am on the phone now, but will post an config asap.
Here are the details from the wireless interface:
 0    name="Guest@home" mtu=1500 mac-address=D6:CA:6D:E5:EC:37 arp=enabled interface-type=virtual-AP master-interface=wlan1 ssid="guest@home" wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
      bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=guest
 1  R name="wlan1" mtu=1500 mac-address=D4:CA:6D:E5:EC:37 arp=enabled interface-type=Atheros AR9300 mode=ap-bridge ssid="wireless@home" frequency=2437 band=2ghz-onlyn channel-width=20mhz scan-list=default
      wireless-protocol=802.11 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
      default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
