hm,
ipsec statistics doesn’t seem to show any rapidly increasing counters.
I do have some static values tho:
> /ip ipsec statistics print
in-errors: 0
in-buffer-errors: 0
in-header-errors: 0
in-no-states: 21399
in-state-protocol-errors: 27
in-state-mode-errors: 0
in-state-sequence-errors: 73
in-state-expired: 0
in-state-mismatches: 0
in-state-invalid: 1599
in-template-mismatches: 5
in-no-policies: 0
in-policy-blocked: 0
in-policy-errors: 0
out-errors: 0
out-bundle-errors: 0
out-bundle-check-errors: 0
out-no-states: 13342
out-state-protocol-errors: 1903
out-state-mode-errors: 0
out-state-sequence-errors: 0
out-state-expired: 1903
out-policy-blocked: 0
out-policy-dead: 0
out-policy-errors: 0
This is the cpu usage during a ~16-17Mbps transfer:
> tool profile duration=10s
NAME CPU USAGE
l2tp all 3.5%
wireless all 0%
spi all 3.5%
ethernet all 7.5%
ntp all 0%
console all 1%
flash all 0%
dns all 0%
firewall all 15.5%
networking all 13%
ipsec all 0%
winbox all 0.5%
mpls all 0.5%
logging all 0%
management all 3%
encrypting all 32.5%
routing all 0%
idle all 8.5%
profiling all 1%
queuing all 4%
telnet all 0%
bridging all 1%
unclassified all 5%
This is in comparison to same transfer with NAT only:
NAME CPU USAGE
l2tp all 0%
wireless all 0.5%
spi all 3.5%
ethernet all 2.5%
ntp all 0%
console all 0.5%
firewall all 5.5%
networking all 3%
winbox all 0.5%
mpls all 0%
management all 5.5%
encrypting all 0%
routing all 0%
idle all 69.5%
queuing all 3.5%
telnet all 0.5%
bridging all 1%
unclassified all 4%
Isn’t firewall cpu usage too high? Or is the firewall process actually deencapsulates l2tp?
Also, there seems something is strange when transfer is performed through L2TP/IPSec VPN.
I’m seeing double packet rate on my first ip firewall filter rule
add chain=input connection-state=established
add chain=input connection-state=related
add chain=input src-address=10.0.0.0/12
add chain=input protocol=ospf src-address=172.16.0.0/27
add chain=input protocol=icmp
add chain=input protocol=ipsec-esp
add chain=input protocol=ipsec-ah
add chain=input protocol=ipv6 src-address=216.66.80.98
add chain=input protocol=gre
add chain=input dst-port=1701 protocol=udp
add chain=input dst-port=4500 protocol=udp
add chain=input dst-port=500 protocol=udp
add action=reject chain=input comment="drop ssh brute forcers" dst-port=22 \
protocol=tcp reject-with=tcp-reset src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist \
address-list-timeout=5d chain=input connection-state=new dst-port=22 \
protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 \
address-list-timeout=1m chain=input connection-state=new dst-port=22 \
protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 \
address-list-timeout=1m chain=input dst-port=22 protocol=tcp \
src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 \
protocol=tcp
add chain=input comment="accept ssh connections from anywhere" dst-port=22 \
protocol=tcp
add chain=input comment="accept connections to http from anywhere" dst-port=\
80 protocol=tcp
add chain=input comment="accept https connections from anywhere" dst-port=443 \
protocol=tcp
add chain=input comment="accept winbox connections from anywhere" dst-port=\
8291 protocol=tcp
add chain=input comment="accept SNMP/trap connections from anywhere" \
dst-port=161,162 protocol=udp
add action=drop chain=input comment="default configuration" in-interface=\
ether10-gateway
add action=drop chain=forward disabled=yes layer7-protocol=ebay-url \
src-address-list=zh
add action=drop chain=forward disabled=yes layer7-protocol=facebook-url \
src-address-list=zh
add chain=input comment="accept RADIUS auth from LAN" dst-port=1812,1813 \
in-interface=bridge-local protocol=tcp
When I disable the first filter rule then packet rate is seen as actual rate but on both rules: ipsec-esp and udp port 1701.
I realize that due to ipsec and l2tp encapsulation traffic passes through input filter “twice” but should I actually see double packet rate? This doesn’t change even if I explicitly set input interface for the first rule.
Any thoughts?
