RB2011 Join the Ports
I Want use the ports 6-10 with the same configuration that my port2, in the port1 i have the WAN and the 2-5 LAN work fine but need use the 6-10, you can helpme please. I use winbox for config the RouterBoard.
Put the port 6 into common bridge with port 2 and enslave other ports to port 6 by setting it as their master port.
I add the new bridge and add the two port into bridge but does not get ip address for DHCP as the port2, i need othe config? and the port2 is down when i créate the Bridge
I have in red color the DHCP for port2
https://drive.google.com/open?id=1o-mH4Ms_QRCFWPnhLGyXUvL9V_TQ70Ys
Here the config new but with the problem in the DHCP
https://drive.google.com/open?id=11kV9gbmVpAXYhHXswxZj5ybo_YjZ_dh9
https://drive.google.com/open?id=19-1J96kI_UNf4NX4s8O1e9kx-YbvTnG4
Haven’t seen your links but what did you expect from the new bridge? I suggested to use the original common bridge.
