Rb2011 Line - usb power reset?
Hello!
Found this page in Wiki - http://wiki.mikrotik.com/wiki/Manual:USB_Features, but RB2011 routers are not mentioned.
Do any of the rb2011 line support this feature?
update: RB2011 does not have this feature enabled in software, hardware for USB power reset is there already.
Thank you
there is a small update, all RB2011 sold and future ones have this hardware features. but it is not implemented in RouterOS jet. Future releases of RouterOS will have this feature enabled.
Very good news!!!
it is confirmed that patch to correct the issue is done and power-reset is working on these boards. so, next RouterOS release will include the changes (5.22 and 6.0rc3)
I have a Router OS 5.22 on RB2011UAS-2Hnd
The command /system resource usb power-reset
returns:
bad command name power-reset (line 1 column 22)
EDIT:
Apologies: correct syntax is:
/system routerboard usb power-reset duration=10s
Hi, how it looks with UPS via USB and RB2011 ? for me it on 6.0RC5 doesn work …
any progres or we must wait for implementation from Mikrotik ?
APC USB ups on RB2011UAS-RM not working, but required !
one year and nothing !!!
What is the relation of your that to USB power reset?
You just posted an unrelated statement here and expect what?
Maybe if you post it as a question in a thread with relevant title you will get an answer.
