Installed a RB2011 Last week for a customer was working great and then WiFi stopped broadcasting this morning. It appears the radio is receiving data as I can run a scan and see nearby access points, but the SSID does not show up on any devices (windows 7pro / apple iphone / android phone / etc). I’ve tried manually inputting the settings and changing channels, removing security profiles, and I can not get it to show up on any devices.
I’m only using 20Mhz channels and very basic config settings to rule out any compatibility issues.
I also upgraded to lastest ROS v.6.31 and firmware 3.24. Still same symptoms.
