RB2011 packet loss on larger packets over wifi
I’m experiencing issues with wifi with packets larger than 500-600Byte.
Basically 15-20% packet loss with ICMP 1000Byte packets. So it isn’t a MTU issue, rather something wrong with the radio on the RB itself.
Smaller packets are not dropped.
Tried both 6.40 and latest bugfix release. Same behaviour.
The setup is pretty simple, RB2011UAS with 3 SSIDs serving as an AP, connected over 1G link to a switch and to the router. Each vAP is in a separate bridge and tagged upstream over a trunk terminated on the router.
AP(ssid1-3) --(vlan1-3)-- switch --(vlan1-3)-- router
I’ve tried to eliminate all the components, and ended up testing the radio only.
I pulled one of the vAP interfaces from the bridge and defined an IP straight on that vAP interface. I’ve seen no change in behaviour when trying to interact between a client and the AP itself.
I proceeded to play further with wireless options but nothing helped.
There aren’t many wifi networks in the neighborhood (<10 SSIDs) to cause interference.
Is the radio possibly dying?
 > interface wireless frequency-monitor 0
         FREQ          USE         NF
      2412MHz           4%       -113
      2417MHz         3.4%       -113
      2422MHz           0%       -111
      2427MHz           0%       -109
      2432MHz           0%       -116
      2437MHz         0.9%       -114
      2442MHz           0%       -116
      2447MHz           0%       -118
      2452MHz         0.6%       -119
      2457MHz         0.6%       -105
      2462MHz         0.6%       -115
      2467MHz         0.6%       -113
      2472MHz           0%       -101
 > interface wireless scan
number: 0
Flags: A - active, P - privacy, R - routeros-network, N - nstreme, T - tdma,
W - wds, B - bridge
       ADDRESS           SSID       CHANNEL    SIG   NF SNR RADIO-NAME ROUTERO...
AP     60:83:34:C3:D6:E0 HUAWEI-... 2412/20/gn -75 -114  39
AP     5C:49:79:DE:3F:E5 FRITZ!B... 2412/20/gn -54 -114  60
AP     98:8B:5D:F2:94:F0 Ivanka 1   2462/20/g  -66 -106  40
 P     2C:95:7F:14:1E:56 KUCNA M... 2462/20/gn -72 -106  34
AP     08:95:2A:5D:68:7D Vip_98049  2412/20/gn -78 -114  36
 PR  B 6C:3B:6B:F6:67:2B CEI-SIG    2422/20/gn -79 -117  38 6C3B6BF... 6.37.5
APR  B 6C:3B:6B:72:83:18 Ares       2412/20/gn -81 -114  33 6C3B6B7... 6.36.4
You have very strong signals from other APs in the neighborhood. Really strong. Like as if they are stacked.
This causes mutual interference that affects mainly larger packets.
Hmmmm
But those are mostly on 2412
Are they really interfering this much on 2437 ?
I must admit I am puzzled how people even use wifi in a crowded apartment building. I can’t imagine I have such a bad situation..
Is there anything I can do here, tweak certain parameters, anything except going 5G?
