Hi all
I have a new RB2011 which has Eth1 as PoE input. However, when I try supply power through this interface (from a Cisco 2960S), the router does not power on at all. The port on the Cisco is able to power a phone/AP when connected.
Any ideas?
A
cisco have IEEE 802.3af - it is 48V POE
it is NOT compatible with rb2011. It support 8-28V
You can use this power converter between cisco and Mikrotik http://routerboard.com/RBPOE-CON-HP
Thank you for the useful information. Will pick some of those up.
