rb2011 - poor performance with uk bt infinity
Anyboidy?
sebus
I haven’t tested it recently (switched to cloud core routers which are higher performance). The rb2011 showing this fault is a few years old now so I hope the latest hardware doesnt have the issue. It doesnt boot reliably anymore anyway so I can’t test for you. If you’re having problems, the workaround is to use one of the 100Mb ports to connect to the modem (change the firewall rules and PPPoE to use eth10) as the issue was with the 1Gb ports.
Pete
It does correctly auto negotiate to 100Mb FD on Gig ports
sebus
