Helo, im having a problem with a PPTP server. It works well for users that are inside the network, but external users cannot connect. On the Log all I get is “TCP Connection established from xx.xxx.xxx.xxx.” After that - no “disconnected”, no nothing. What am I doing wrong? Firewall filter rules are:
0 chain=input action=accept protocol=tcp dst-port=1723
1 chain=input action=accept protocol=gre
2 chain=output action=accept protocol=gre
3 chain=output action=accept protocol=tcp dst-port=1723
Can you output your entire IP firewall filter?
/ip firewall filter export hide-sensitive
same trouble, what wrong ?, my firewall
add chain=input comment="Allow gre" protocol=gre
add chain=output protocol=gre
add chain=input comment="Allow port 1723" dst-port=1723 protocol=tcp
add chain=output dst-port=1723 protocol=tcp
add chain=forward comment="Allow all subnets" dst-address-list=LocalNet \
src-address-list=LocalNet
add chain=input comment="Allow ping" protocol=icmp
add chain=forward protocol=icmp
add chain=input comment="Allow estabilished" connection-state=established
add chain=forward connection-state=established
add chain=input comment="Allow related" connection-state=related
add chain=forward connection-state=related
add chain=input comment="Allow UDP" protocol=udp
add chain=forward protocol=udp
add action=drop chain=input comment="Drop invalid" connection-state=invalid
