RB2011: ROS 6.20 + Metarouter guest 5.26 ?
Hello.
Can I run Guest with 5.26 ??? on a RB2011 with 6.20 host?
no, it is not possible using MetaROUTER. If you are running RouterOS you will be running same RouterOS version as the host. (with same packages installed as on host)
thank you
