RB2011 series - PoE output function for port #10
IN specifications to RB2011 series(RB2011LS-IN\RB2011L-IN\RB2011LS-RM) say:
There is PoE output function for port #10 - it can power other PoE capable devices with the same voltage as applied to the unit. Maximum load on the port is 500mA.
but i can find PoE-options in menu (((
if connect port #10 of 2011 to 1st port 951-2N (951-2N don’t get power)
So how make PoE work on port #10 of RB2011 series ?
now works only in terminal
can you post command to enable PoE !
http://wiki.mikrotik.com/wiki/PoE-Out#How_it_works
/interface ethernet poe set ether10 poe-out=forced-on
6.5 \ 6.6 NOT work (((
in what version it must work?
but on 5.24 \5.26 comand works BUT no power get from port (
Is PoE output @ port 10 (still) available on RB2011UAS-RM? I’m running 6.13 and can’t make it work. I can’t even run terminal commands for PoE status or setup.
please look for small letter ‘i’ so, RB2011-UiAS etc.
Initial RB2011 has no ‘i’ moniker
Thank you for your answer. I have initial UAS device without “i” and no yellow lines around Ethernet port 10 so I guess this unit has no PoE capabilities.
by indications you mention - you are correct.
My mikrotik router has an “i” AND yellow lines w/ power plug icon on port #10… but I’m having problems with POE still…
[admin@MikroTik] > /interface ethernet poe set ether10 poe-out=forced-on
[admin@MikroTik] > /interface ethernet poe monitor [find]
;;; Conference Room Phone!
poe-out-status: powered-on
[admin@MikroTik] >
Nothing happens to our VoIP device. (polycom starfish soundstation ip 7000)
It works fine when plugged into a regular ole Enginius poe switch.
Any ideas? Thanks! :smiley:
Your device want 48V PoE, not 12/18/24 PoE
thanks, i was going to search for that. :slight_smile: you are right.
http://www.newegg.com/Product/Product.aspx?Item=9SIA19P1D68959&nm_mc=KNC-GoogleMKP&cm_mmc=KNC-GoogleMKP-_-pla-_-Phone+%26+Conferencing+Devices-_-9SIA19P1D68959&ef_id=UtbfJwAABfdndhd3:20140528031703:s
i wonder why my poe switch (engenius brand) works then…it must support up to 48V.
and i guess mtik doesn’t. :\
thanks!!
my RB951 with 48V POE control :
https://drive.google.com/folderview?id=0B8uP6lMFhyXcLWIxTWwwQ1I1U2s&usp=sharing
Brilliant!
