RB2011 UAS-IN and LTE adapter
Good afternoon.
I try to connect USB LTE adapter BaudLuxe C501 to RB2011 UAS-IN. I found this adapter in supported hardware list. But when I connect it to router /interface lte menu still empty. I tried to upgrade RouterOS to latest version without any result.
[admin@MikroTik] > /system resource usb print
DEVICE VENDOR NAME SPEED
0 1:1 RB400 EHCI 480 Mbps
1 1:5 BandRich, Inc. BandLuxe HSPA-LTE Adapter 480 Mbps
[admin@MikroTik] > /interface lte print
Flags: X - disabled, R - runningAny suggestions?
one obvious question: the USB stick powers up? So you can see lights going on onto it?
Maybe there is not enough power to make it work correctly.
I had to use a CradlePoint Modem for the Verizon LTE install I did. It was set up as a backup/split with a T1. The 750GL was dividing the traffic. When the T1 kept going down… well the LTE is the only connection now.
On verizon they Nat the 4G systems. So no external access without a proxy or dialer out.
please contact support@mikrotik.com and include the support output file in the email.
Will there be support 3g modem bandluxe c331?
