RB2011 UIAS-RM stuck in a blank screen, can't do a NetInstall or factory reset
Hi guys, i bought a RB2011 for my homelab and when i turned on it just shows a blank screen. When i try to press the reset switch to factory reset it or even NetInstall, it just don’t do anything at all, no green LED flashing or device rebooting, as the manual implies. When i connect it to my ISP Router, it acts like a dumb switch.
Any ideas for solving this?
You do not provide any relevant detail, like RouterBOARD exact model, RouterOS used, OS used for netinstall, etc.
But if correctly used netinstall do not reboot correctly the device, is gone.
