RB2011 wireless speed very low
I reconfigured my RB2011 that I have since 2015. There was some issues with the speed and stability of my network.
After the reconfiguration it did not improve on the speed. If I check my providers speeds it is close to 280mbit/s while on the TIK I have 20 ~ 30 mbit/s and wired it is 202mbit/s but that is very much fluctuating.
I checked the power, CPU usage disabled the LCD etc all these actions did not improve my wireless network. Is there anyone who can help me on this one ? I’m depending on my network for smart home applications etc.
2.4GHz radios are subject to interference, not only other WiFi networks but also other sources. If I’m correct there is a WiFi scanner option that you can use to search for the best channel: you might want to select manually from either 1, 6 or 11.
To get a better view on the problem, can you please post /interface wireless export hide-sensitive?
Hi sure,
[admin@MikroTik] > /interface wireless export hide-sensitive
jun/16/2020 17:46:52 by RouterOS 6.47
software id = IWVK-GRSK
model = 2011UiAS-2HnD
serial number = xxxxxxxxxx
/interface wireless
managed by CAPsMAN
channel: 2452/20-Ce/gn(16dBm), SSID: xxxxxx, CAPsMAN forwarding
set [ find default-name=wlan1 ] country=xxxxx frequency=auto mode=ap-bridge ssid=“xxxxx” wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
/interface wireless cap
set bridge=bridge1 discovery-interfaces=bridge1 enabled=yes interfaces=wlan1
Looks like you are using CapsMan…could you please show your /capsman export hide-sensitive? Besides…only use WPA2/AES.
my export of CAPSMAN:
[admin@MikroTik] > /caps-man export hide-sensitive
jun/16/2020 18:13:13 by RouterOS 6.47
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm,tkip name=SecurityMain
/caps-man configuration
add country=belgium datapath=DataPathMain mode=ap name=“Main configuration” security=SecurityMain ssid=“xxxxxxx”
/caps-man datapath
add bridge=bridge1 client-to-client-forwarding=yes local-forwarding=no name=DataPathMain
/caps-man interface
add configuration=“Main configuration” datapath=DataPathMain datapath.bridge=bridge1 disabled=no l2mtu=1600 mac-address=E4:8D:8C:28:FE:0F master-interface=none name=RB2011 radio-mac=E4:8D:8C:28:FE:0F radio-name=E48D8C28FE0F security=SecurityMain
add configuration=“Main configuration” disabled=no l2mtu=1600 mac-address=C4:AD:34:06:7F:3C master-interface=none name=cap1 radio-mac=C4:AD:34:06:7F:3C radio-name=C4AD34067F3C
/caps-man manager
set enabled=yes
I use Capsman for my outside antenna
