RB2011 with ROS6.1 and NTP packet can't boot
I tried upgrade my RB2011 from ROS6.0 to 6.1, but it can’t boot, lcd stay on “starting service”, I use console to check it, it show below error:
verified ntp-6.1-mipsbe.npk
verified routeros-mipsbe-6.1.npk
installed routeros-mipsbe-6.1
installed ntp-6.1
Restarting system.
RouterBOOT booter 3.05
RouterBoard 2011UAS-2HnD
CPU frequency: 600 MHz
 Memory speed: 225 MHz
  Memory size: 128 MiB
    NAND size: 128 MiB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
MikroTik 6.1
RB2011UAS-2HnD-IN Login: Oops[#1]:
Cpu 0
$ 0   : 00000000 7fc45038 000000b1 ea2c8000
$ 4   : c75ad380 000002e9 00000004 00000007
$ 8   : 00000020 c0239dd0 00000000 00000000
$12   : 7fc45030 00000200 00000002 00000000
$16   : 00000001 00000000 00000006 00100000
$20   : 00000001 c7dd3380 00000000 20010000
$24   : 00000000 c6f91040
$28   : c764a000 c764bd08 00000001 c6f73ca8
Hi    : 00000004
Lo    : 92de8000
epc   : c6f73ca8 ath8327_flush_hosts+0x9c/0x320 [ath8327@0xc6f70000]
    Not tainted
ra    : c6f73ca8 ath8327_flush_hosts+0x9c/0x320 [ath8327@0xc6f70000]
Status: 1000fe02    KERNEL EXL
Cause : 40808008
BadVA : 0000022c
PrId  : 0001974c (MIPS 74Kc)
Process net (pid: 245, threadinfo=c764a000, task=c746b3c0, tls=775a5770)
Stack : 00800800 c6f70618 00000000 00000000 c75ad380 c75ad380 00000002 00000006
        00000000 00000001 c7dd3380 c6f73e48 00000000 00000000 00000000 000008c8
        00000000 00000000 c75ad380 00000006 c7dd3380 00000004 00000001 c7dd3380
        0045f370 00000000 20010000 c6f480b8 c764be28 00000000 7fc45fe8 0045f370
        c7dd2b80 00000002 c764be28 00000000 7fc45fe8 c6f4a438 00000001 c6f70264
Call Trace:
[<c6f73ca8>] ath8327_flush_hosts+0x9c/0x320 [ath8327@0xc6f70000]
Code: 000000c0  0dbdcf03  3c130010 <8e22022c> 3c140020  8c520000  2444fff8  2635022c  2652fff8
---[ end trace 2cc66f307ebd5160 ]---
rb400_beep 5000
rb400_beep 0
rb400_beep 5000
rb400_beep 0
rb400_beep 0
Rebooting...
Stopping services...
failed to stop racoon: std failure: timeout (13)
I tried upgrade 2 times, and re-download both update and ntp packet, then check MD5, they are match the MD5.
Now I reinstall 6.0 are no problem.
Thanks a lot.
When i upgraded my rb2011,I had similar problem.It just reboot and reboot…
And I pressed reset button,then it works.
Maybe it’s a bug I have no idea.
