I have a RB2011iL-IN router and I’m trying to connect a mAP lite via PoE. Everything is fine when I use a PoE injector with DC12V, but there is no power when connecting the mAP lite to the RB2011 ether10 port. I measured the voltage on the ether10 port and there is about 10 volts without a connected device and about 6 volts when the mAP lite is connected. The DC24V 1.2A power supply is used for the RB2011, so I expect to see about 22 volts at the PoE output.
Can someone help me to understand this issue? I think there is a problem with the RB2011, but I’m not sure.
