Hi all,
After browsing through the forums, i believe there are a lot of users facing the same problem.
- Random reboots
- Memory leak
- Kernel panic
I have been going through the above randomly where I came to a point of frustration, the symptoms perhaps already been there for a while but I did not notice until it became worse a few days back when the unit keeps on rebooting with interval around 1 hours.
But i do find very weird symptoms like, when I do a continuous ping to the Mikrotik itself, sometime, the connection simply dropped, the internet connection is still going, but for local to ping the Mikrotik (and internet), the connection dropped, the ping itself lost around 10-15 times then reconnected. I have tried changing to other PC, other units, different hosts. all experience the same issue. Ping from internet, while there is no dropped, but during the internal “packet dropped” period, the ping respond from Internet somehow spike to 10 times. For example: if a usual 5ms ping, will become a 50 to 100ms ping external while Timed Out on the internal.
This can happen anytime, no specific time and the interval between can be a few mins to several hours. But it does happen. After some time for this issue, the next thing will be reboot with a lot of different message like above.
I have tried, upgrade all the firmware/bios to latest. And tried downgrade. However this still happens and it is driving me crazy. (current version using is 6.24). I do have some PCR but just less than 5 rules, and does not using any Queues at all.
I just sent an email with sprout file to Mikrotik and hope response.
Any one facing similar issue and if there is any fix? or my unit faulty?
If possible, i do not want to try, reset, reformat, reinstall or other units as this unit the configuration is pretty complicated. I do have the backup file but still…
Anybody please can help?
Thank you very much.
