RB2011IsAS-RM - eth10 dead?
I have an RB2011IsAS-RM to play with. I was hoping to set eth10 as my management access port, but I have a feeling it’s dead.
Setting an IP address, DHCP etc works fine, but I can’t connect to the board through this NIC. I know it’s a PoE out port, and I’ve disabled that feature since I won’t need it. I don’t think that would be the issue. Anything else I can check, or need to do, to get this port to work? It shows up just fine in the interface list, but even trying to connect the router with Winboc via its MAC address doesn’t work.
Is that port dead, then?
Remove that port from bridge if it’s not already the case.
Thanks, I have no bridges set up.
Any other suggestions?
Nevermind… my error of course. Typo in IP addressing. Port is working just fine. Thanks for looking and trying to help out.
