Hey All,
I have acquired a 2011L-IN that had previously had The dude installed and I’ve read that the only way to get rid of the dude is to do a netinstall which requires console. I have also factory reset the unit but Dude is still running and consuming all of the storage. From CLI I issued the
/system console print (No Ports Show Up)
If I go to System > Console in GUI then try to add port it shows up as unknown.
Any help would be greatly appreciated. The ultimate goal is to remove The Dude from this unit so I can free up the file system and use it as an actually firewall in place of a RB751.
Thank You!
