Looking for suggestions since my new RB2011L-IN is basically non-responsive. An RB751G purchased at the same time works perfectly.
Power light - Solid
Link lights - flash once within 1s of power
FastEthernet ports do not show link (even when attached computer is forced to 100 or 10 Mbit)
Gigabit ports show link activity from attached PC and Mac computers
Connected systems go to zeroconf IPs (even when attached computer is forced to 100 or 10 Mbit)
Holding the RESET button during power up (for up to 5 minutes) does not cause the “LED to starts flashing” per the manual.
System does not show up in NetInstall. Although I suspect that I’d have to use the RESET button to force PXE but given it doesn’t behave as documented I think this might be possible.
Are you sure you used port 2-10 to connect, not port 1, which is firewalled? Your problem sounds slightly different than in the original post, as bhorrock wasn’t able to reset it.
I had no Link at all on the FE ports when anything was plugged in to when I got the Router . GE Ports came up but could not talk to the router in anyway until I hard reset it via the reset button inside.
Suggestions?
My suggestion is to hold reset button before power is applied.
Hold reset button and apply the power, hold for 5-20 seconds and release. There is no reason to hold reset button for 5 minutes.
Make sure Ethernet cable is connected to Ether1 of RB2011 and Netinstall uses correct configuration on computer (netbooting IP address, firewall, etc.).
