Hi!
That’s the problem
Tried to roll back to 5.23 after NetInstall.
Netinstall put through 5.24.
Nothing has changed. How can I solve the problem?
thanks
Sorry for the bad english!
Hi!
That’s the problem
thanks
To confirm, you either:
/system packages downgrade
and nothing happened, not even a log file entry?
If you did not use Netinstall, rebooting without using the downgrade option will result in a log entry saying something along the lines of newer packages already exist and no action was taken.
I did not write in English…
sorry
The / health systems print on both versions will not work!
Maybe it’s a hardware problem?
To version 5.20, I did not check.
I’m sorry, I don’t have a 2011LS to verify, but the spec sheet says it has no voltage monitor, no PCB temperature monitor and no CPU temperature monitor (http://routerboard.com/RB2011LS), so I’m not sure what else you expect to see in system health. The RB600, 800 and 1000 series (and possibly others) showed active and backup fan status in system health, but the 2011LS has no fans either.
Did it previously show you some data in system health?
Oh thank you!
It is clear that this is not much need.
Especially because everything else works just fine! ![]()
