Looking for help and direction.
Have been getting to know and love RB2011U. (great wifi penetration! )
I have been looking for all the information I can about how to attach USB devices to RB2011.
I think I have the part about having everything plugged in to the RB2011U and rebooting (I see Motorola A956 when I print USB)
But when I /port print I only see serial0 Serial Console..???
No ports show up in the port menu either.
The Motorola is running Android 2.3.4.
Usually I tether to a PC using a piece of software called “pdanet”
The software has a piece in the phone and a piece on the PC, I select USB and we get a fast connection !
Not I would like to remove the PC from the equation and just have the A956 USB’d off the RB2011.
Is that possible? Seems it should be, right?
I am running RouterOS 6.31 and Routerboard 3.24
Could I get pointed in the correct direction?
