RB2011uas-2hnd disconnecting all clients!?
few years I am using RB2011uas-2hnd and all was fine but now some time I have strange problem, after few days normal work it simple start to drop-disconnect all wireless clients and on retry it simple again disconnecting all of them with errors like:
disconnected, unicast key exchange timeout
disconnected, received deauth: sending station leaving (3), signal strength
I have up to 10 wifi clients and it can work many days without problems and than simple start this and after reboot problem is same, only solution that working is to change from channel 1 to channel 6 and that all start to work normal and than if I again in few minutes back to channel 1 it also continue to work normal!!! How this can be possible and why?
If I leave it on channel 6 it also will work some time and than will start same problem and than I must simple change to any channel and all will start to work normal!
I must say that this is rural area with few houses around and look like is not problem networks around my place!
Thanks.
