RB2011UAS-2HnD-IN after purchasing the default configuration has the Wifi adapter turned off. In the list of interfaces, there is no interface WLAN1. The device is physically mounted WIFI.
please go into the system package and check if the wireless package is enabled or not. If it isn’t enabled, then enable it and reboot the router and the wireless interface should appear.
