Unfortunately you can’t use a serial cable to try and see what is going on. Can you RMA it?
keyafay
February 19, 2014, 3:08am
3
Unfortunately, I bought it over the internet though a vender on amazon. I can’t seem to contact them.
I hate to ask. What would be my options?
jarda
February 19, 2014, 1:51pm
4
Try other power adapter - 24V 1A would be enough for sure. Do not give up with trying to catch netinstall mode. If finally failed, serial link is the last option.
Sent from Android by Tapatalk.
plisken
February 19, 2014, 5:14pm
5
keyafay:
I have run into a issue.
Details
When I plug in the router, the LED flashes, than gose black (No image saying booting the kernel or configuration).
Both lights next to the USB plug are light up.
my computer wont recognize the Ethernet. It dos a continual search for the connection.
When I plug in my computer, the router light will light up under the port light along with any other connection.
reset button dose not work.
PC OS is windows 7
Please help
http://www.wirelessinfo.be/index.php/mikrotik/pages/seriale
See for serial connect
For netinstall see this, is dutch but follow the printscreens a made
http://www.wirelessinfo.be/index.php/mikrotik/pages/netinstall
If that not helps pleace take contact to support@mikrotik.com
