Hi, I got a RB2011UAS-2HnD-in recently and been trying to set up my network.. My knowledge in Networking is rather limited, although I did get the network up and running by reading around..
My config is like this:
Ether1 is connected to a cable modem
Ether 2-5 has Ether1 as master port
Ether 7-10 has Ether6 as master port (as it comes out of the box)
Ether1, Wlan1, Ether6 are bridged.
With this config all the devices connected to the ethernet ports (2 to 6) and all the wireless clients can accesss each other and the internet.
What I would like to do is, Mirror all the traffic coming in and out of the network, to a port which can then be used to run snort.. So I’ve added Ether1 as Mirror source and Ether5 as mirror target, but it doesnt seem to work as snort can’t see any traffic on ether5..
I read a few other posts on mirroring and someone had suggested using a rule to mirror the port which again I tried with no success..
Some Output from the terminal:
[admin@RB2011] > interface ethernet print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 X sfp1-gateway 1500 D4:CA:6D:8E:45:A9 enabled none Gigabit
1 R ether1-Gateway 1500 D4:CA:6D:8E:45:AA enabled none Gigabit
2 RS ether2-DNS-DHCP 1500 D4:CA:6D:8E:45:AB enabled ether1-Gateway Gigabit
3 RS ether3-FreeNAS 1500 D4:CA:6D:8E:45:AC enabled ether1-Gateway Gigabit
4 RS ether4-PC 1500 D4:CA:6D:8E:45:AD enabled ether1-Gateway Gigabit
5 RS ether5-MirrorTarget 1500 D4:CA:6D:8E:45:AE enabled ether1-Gateway Gigabit
6 ether6-Printer 1500 D4:CA:6D:8E:45:AF enabled none FastEthernet
7 S ether7-slave-local 1500 D4:CA:6D:8E:45:B0 enabled ether6-Printer FastEthernet
8 S ether8-slave-local 1500 D4:CA:6D:8E:45:B1 enabled ether6-Printer FastEthernet
9 S ether9-slave-local 1500 D4:CA:6D:8E:45:B2 enabled ether6-Printer FastEthernet
10 S ether10-slave-local 1500 D4:CA:6D:8E:45:B3 enabled ether6-Printer FastEthernet
[admin@RB2011] > interface ethernet switch print
Flags: I - invalid
# NAME TYPE MIRROR-SOURCE MIRROR-TARGET SWITCH-ALL-PORTS
0 Gigabit Atheros-8327 ether1-Gateway ether5-MirrorTarget
1 FastEthernet Atheros-8227 none none
Can anyone guide me in the right direction as to how to get this to work, or perhaps how to test if mirroring actually work and if it’s my IDS that’s not doing the job.. Thank you very much for any help you can give me
