rb2011uas-2hnd-in routeros metarouter
Hi
I received my new rb2011uas-2hnd-in two days ago, upgraded to 6.0rc2 and tried to use metarouter.
Right after pressing ok router just reboots…
Is it only my machine, or something in ros6?
Downgrade to 5.21 solves problem - I can create metarouter and start it just fine.
Any help is appreciated.
Serial console log:
[quote]RouterBOOT booter 3.0
RouterBoard 2011UAS-2HnD
CPU frequency: 600 MHz
Memory speed: 225 MHz
Memory size: 128 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Starting…
Starting services…
MikroTik 6.0rc2
R02 Login: Kernel panic - not syncing: Attempted to kill init!
panicSaver: dumping panic to flash
flash: erase f
flash: prg f
spi_program_sector 0000000f
Rebooting in 1 seconds..
Memory size: 128 MB
Boot configuration CRC error, applying defaults
writing settings to flash… OK
Press any key within 2 seconds to enter setup..[/quote]
it will be resolved in 6.0rc3. Here is pre-built that is working:
http://www.mikrotik.com/download/share/routeros-mipsbe-6.0rc3.npk
