RB2011UAS-2HnD-IN unresponsive/defect touch-LCD
I just bought a RB2011UAS-2HND-IN, the touch screen is incredible insensitive. After many tries I may be able to change screen (if I have the luck on my side). I tried “/lcd reset-calibration”, but there are no reaction when I try to press on the first “X”.
Do I have a defective unit or is it a design-flaw?
Does the calibration work at all?
Can anyone confirm that entering “/lcd reset-calibration” and pressing the “X” doesn’t do anything at all? Tested with fingers, nails and stylus.
We have improved the calibration process in RouterOS v5.21 (not yet released). If you want to test it, email support@mikrotik.com for early access.
Thanks, mail sendt. :slight_smile:
No improvements for the calibration, it doesen’t register when I press the “X”. Tried finger, nail and stylus. Pressing, holding, swiping, no response what so ever. The touch it self seems littlebit more responsive, could be just me geting used to it…
Mine RB2011UAS-2HnD-IN is the same -touch display is unresponsive and/or defect - only some kinds of triangles appears on it with message Interface down. Shame.
[admin@MikroTik] > system lcd
[admin@MikroTik] /system lcd> ex
sep/29/2012 17:10:06 by RouterOS 5.20
software id xxxxxxxxxxx
/system lcd
set contrast=0 enabled=yes port=serial0 type=24x4
Are this settings correct ?
These settings are not correct. LCD touchscreen is configurable under “/lcd” menu. “/system lcd” menu from optional LCD package is used for LCD displays.
RB2011 LCD manual: http://wiki.mikrotik.com/wiki/Manual:LCD_TouchScreen
Ah - that’s right - everything is fine now. Thanks. Everything works now.
like espencb, I’ve just received a RB2011UAS-2HnD-IN. It works very well except for the LCD screen that is unresponsive to touches too.
I’ve done all upgrades (now I’m in firmware 3.0 and routerOS 5.21, bundled version was rOs 5.20) but the calibration still not work: I’m not able to register the first cross to push due to unresponsive screen.
I hope the next rOs release will fix that or I will deduce the LCD is defective :-/
Make sure you press hard. This is not an iPhone display (capacitive type), this is a resistive display, where pressure registers your selections. Try to press harder, or use a pencil (or some other not-very-sharp object)
I guess it’s a resistive display but if I press harder I will break through the enclosure. I’ve tried with a pda pencil, same result.
I don’t know if espencb has resolved the problem with rOs 5.21, maybe we have a lcd serie issue or the resistive display is bulletproof :smiley: .
If you upgraded to v5.21 and did the “reset calibration” command, and it still doesn’t work, you must return it to the seller. It could be a defective panel.
LCD Display is unneeded feature. It would be much better to have faster CPU at RB2011. The router is not a toy for childrens !!!
We have cheaper models without LCD
And without voltage monitoring :frowning:
Voltage monitoring is VERY good feature at RouterBoard. We use it to monitor DC UPS voltage.
But who will climb at 100m tower to loo look at RB LCD ?? :slight_smile:
RB2011 comes in an indoor case, so it’s more targeted at the home/office users, who hang it on the wall (it has wall mounts).
OK, but what for is LCD at RouterBOARD 2011UAS? And 600MHz CPU :frowning:
It’s rack-mount router, that is at sever’s room - we are getting in there one time per month.
Normis, I want to tell You, that MUCH better solution would be to use better CPU and NO LCD!!!
Router ir router. And MikroTik OS is very good system. So we don’t want to use it to display movies :wink:, but - we need better performance, stability and features.
RB2011 CPU is one of the best we have now. Have you tested it? It is the best of all our MIPS products. Why do you need faster?
I like the LCD Normis. Looks great in my living room.
wow, you’re saved my day !! tnx & happy New Year !
im actually purchased my 2011[non-RM wariant with WiFi and LCD] and nearly start feel sorry about not picking RackMount-version instead[despite absence of (rarely used until now)WiFi], because fragile-looking enclosure, [not laugh:]red color in front and LCD in weird state - protective cover scrateched, partially removed[“by force”]/twisted and half-screen not touch sensetive.
after reading THIS thread i discover than LCD was left in “Disabled” state and locked to [not used yet]SFP cage. i guess wrong defaults in RouterOS config[i was used 6.0rc5].
after doing two [unsuccessfull]attempts to re-calibrate LCD, i was kinda desperate, but after third time - its WORKING !! :stuck_out_tongue:
and found LCD really helpful !![never before big fan of displays in networking.
also discover scary button with “Reset” title :stuck_out_tongue:
p.s.
wonder how far “Screen race” coul lead networking designers/manufacturers soon. 4’’ screen on router, anyone ? 6’’ maybe ? :wink:
