RB2011UAS-2HnD-IN..
I would want to try the AP RB2011UAS-2HnD-IN. Which are principal technical differences with the RB711UA-2HnD ?
In a configuration WDS-MESH can coexist?
Basically no differences configuration-wise. All the config through winbox is the same, you can use WDS no problem between them.
Ok,
but RB2011UAS-2HnD-IN is superior or inferior to RB711UA-2HnD ?
thanks
RB2011 has more ports, is a little bigger, has different RAM and CPU. The CPU on the RB2011 is newer generation, and should be a little faster. I would say that they are completely different products.
Ok but I’m supposed to use them for a configuration WDS-MESH ( http://wiki.mikrotik.com/wiki/Wireless_WDS_Mesh / model2 ) in a condominium with more apartments.
I am undecided whether to use RB2011UAS-2HnD-IN or RB951G-2Hnd. what do you recommend ?
RB2011UAS-2HnD-IN or RB951G-2Hnd will be identical in WDS functionality. Their biggest difference are number of port and physical looks/size/design. They have same CPU and same amount of RAM so performance will also be similar. RB2011 has external antennas, and they can be changed to other ones (MMCX connector) so that provides better flexibility and more coverage.
