good night
I have little knowledge mikrotik, but I would ask for a little help for configuration vlan networks using a RB260GsP.
My scenario is as follows:
I performed the configuration using this post directly linking the RB411AR and RB2011UAS-2HnD and it worked perfectly. but I need to use the RB260GsP due to PoE. but I’m having a lot of difficulty in the VLAN configuration in this scenario.
http://forum.mikrotik.com/t/rb750g-rb411ar-and-vlan/49592/4
RB2011UAS-2HnD is a manager of internal network it separates the two networks vlan.
I tried to create two trunk between the involved Routerboad’s and RB260GsP and maintain other devices connected to VLAN 100 (internal), my internal devices are not using VLAN ID in my settings’m trying to set them to operate transparently.
When I turn on the RB they work for 15 minutes and after that they are inaccessible randomly.
Winbox finds all RB but I can not access them via IP or MAC
My internal network is 192.168.141.0/24
My client network is 130.155.0.0/16
RB2011UAS-2HnD
After 15 minutes
next post I detail a RB411AR config.
