I have a Dell PowerEdge 2970 which doesn’t want to PXE boot, error is: “No PXE-capable device available”.
I can confirm that the server’s IP address is 192.168.88.20, netmask 255.255.255.0 and gateway 192.168.88.1. It gets the network config via DHCP, it’s not statically configured.
The RB2011-UAS is setup as follows:
[admin@MikroTik] > /ip dhcp-server network export
# mar/23/2014 00:26:33 by RouterOS 6.11
# software id = 0YXJ-NGJP
add address=192.168.88.0/24 boot-file-name=pxelinux.0 comment="default configuration" dns-server=192.168.88.1 \
gateway=192.168.88.1 next-server=192.168.88.1
[admin@MikroTik] > /ip tftp print
Flags: X - disabled
# IP-ADDRESSES REQ-FILENAME REAL-FILENAME ALLOW READ-ONLY ALLOW-ROLLOVER HITS
0 192.168.88.0/24 pxelinux.0 usb1/tftp/pxelinux.0 yes yes no 0
1 192.168.88.0/24 bootmsg.txt usb1/tftp/bootmsg.txt yes yes no 0
2 192.168.88.0/24 memdisk usb1/tftp/memdisk yes yes no 0
3 192.168.88.0/24 pxelinux.cfg/default usb1/tftp/pxelinux.cf... yes yes no 0
4 192.168.88.0/24 mini.iso usb1/tftp/mini.iso yes yes no 0
[admin@MikroTik] > /file print
# NAME TYPE SIZE CREATION-TIME
0 usb1/lost+found directory mar/22/2014 23:06:53
1 usb1/tftp directory mar/22/2014 23:15:23
2 usb1/tftp/bootmsg.txt .txt file 199 mar/22/2014 23:15:22
3 usb1/tftp/mini.iso .iso file 21.5MiB mar/22/2014 23:15:24
4 usb1/tftp/memdisk file 25.5KiB mar/22/2014 23:15:23
5 usb1/tftp/pxelinux.0 .0 file 16.4KiB mar/22/2014 23:15:23
6 usb1/tftp/pxelinux.cfg directory mar/22/2014 23:15:23
7 usb1/tftp/pxelinux.cfg/default .cfg/default file 161 mar/22/2014 23:15:23
8 usb1 disk mar/23/2014 00:28:27
Not sure where the problem is. There’s nothing in the logs.
