Hello
I have a RB2011UAS-RM with 5.25
I have in the past downgraded the routerboot firmware to 2.41 with success.
Now I am going to upgrade to 3.07 (I hope that crashes that happened with 3.02 will not be here) but even if it tells that routerboot was upgraded successfully, after reboot I still get 2.41.
this is my conf
baud-rate: 115200
boot-delay: 2s
enter-setup-on: any-key
boot-device: nand-if-fail-then-ethernet
cpu-frequency: 600MHz
boot-protocol: bootp
enable-jumper-reset: yes
force-backup-booter: no
silent-boot: no
I did as you pointed me, but the firmware is still 2.41
