RB2011UAS-RM
Has anyone used these?
Mine came with 6.1 install. I deleted some bridge ports and it rebooted in to and endless loop. These were ready to be put on-site. Really annoyed. Are these things stable? From reading it doesn’t seem to be.
I’m using one and yes they are stable … I’m on v6.1 too. However, the software does have bugs and v6 is undergoing heavy changes at the moment. Being a new unit you may have a hardware fault. Restore the config and maybe we can help you.
If you’re familiar with netinstall, I would definitely go that route and try to install 6.2 to see if stability improves. I’ve had many strange issues solved with netinstall.
http://wiki.mikrotik.com/wiki/Manual:Netinstall
Have upgraded and will test again.
Is there any difference between the two port sections (1gbit and 100mbit)? I was going to set wan on the 100mbit side and use the gbit side as a switch?
The only thing I’m aware of is that, on reset ether1 is WAN and ether2,3,4,5,6 are in bridge (switch) mode. Also make sure that you’re using a properly terminated gigabit patch cable.
All working… must have been a bug in 6.1. I remember seeing the same issue in the RC’s.
Found it was a faulty Zyxel AP (hate those things) on the network. Upgrade it’s firmware and we’re in business.
