RB2011UiAS-2HnD + 2 mAP lite over eth as WIFI extender ?
hi folks I’m looking after help with my home setup. main router ( RB2011UiAS-2HnD) is located in the middle of the house, ( technical room) and i would like to extend wifi to rest of the house also corner are of garden due watering system etc. i did purchase 2x RBmAPL-2nd but I’m totally struggling get them operational and keep wifi stable.
current setup from main router is 2 SSID ( main + guest )
i connect 1st mAP and over own wifi use WISP AP . i get IP from DHCP of main router > I allow NAT , allow DHCP and i do final WIFI setup on mAP with same settings. reboot , i get connection but no internet .. i was able once manage get internet but only to 1 device at home rest indicated connection but no internet.
i tried all kind of guides videos and ended up here as last hope before full swap to another vendor more friendly
thank you for any guidance
Karol
