I’ve did everything over the serial console. The plan was to upgrade software and then reconfigure the device.
However, in the middle of the process it broke. I updated RouterOS, issued a configuration reset, and it isn’t booting anymore. The complete console log is attached below:
[admin@MikroTik] /system package update> check-for-updates
channel: current
current-version: 6.40.3
latest-version: 6.49.1
status: New version is available
[admin@MikroTik] /system package update> set channel=
bugfix current development release-candidate
[admin@MikroTik] /system package update> /
[admin@MikroTik] > system package
Software packages can be installed on a router. Existing packages can be uninstal
led and upgraded.
.. -- go up to system
disable -- Disable items
downgrade -- Downgrade the software version to the one which packages are uploade
d to the router
enable -- Enable items
export -- Print or save an export script that can be used to restore configuratio
n
find -- Find items by value
get -- Gets value of item's property
print -- Print values of item properties
uninstall -- Tagged packages will be uninstalled on reboot
unschedule --
update --
MikroTik 6.48.5 (long-term)
MikroTik Login: admin
Password:
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 6.48.5 (c) 1999-2021 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
[admin@MikroTik] > export
# nov/22/2021 07:58:51 by RouterOS 6.48.5
# software id = XXXX-XXXX
# model = 2011UiAS-2HnD
# serial number = XXXXXXXXXXXX
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether7 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether8 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether9 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether10 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 country=no_country_set frequency-mode=manual-txpower ssid=MikroTik station-roaming=enabled
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
/ip dhcp-client
add disabled=no interface=ether7
set channel=long-term
[admin@MikroTik] > system re
resource reboot reset-configuration
[admin@MikroTik] > system reset-configuration
caps-mode --
keep-users --
no-defaults --
run-after-reset --
skip-backup --
[admin@MikroTik] > system reset-configuration skip-backup=yes no-defaults=yes keep-users=no
Dangerous! Reset anyway? [y/N]:
y
system configuration will be reset
Rebooting...
Restarting system...
RouterBOOT booter 3.33
RouterBoard 2011UiAS-2HnD
CPU frequency: 600 MHz
Memory speed: 200 MHz
Memory size: 128 MiB
NAND size: 128 MiB
Press any key within 2 seconds to enter setup..
loading kernel... kernel not found
Please, check ethernet cable...
Ethernet link absent...
trying bootp protocol................................. failed
kernel loading failed
NAND size: 128 MiB
RouterBOOT-3.33
What do you want to configure?
d - boot delay
k - boot key
s - serial console
n - silent boot
o - boot device
f - cpu frequency
r - reset booter configuration
e - format nand
w - repartition nand
g - upgrade firmware
i - board info
p - boot protocol
b - booter options
t - do memory testing
x - exit setup
What’s going on? How to repair this?
I admit, I must have been updated RouterBoot as well, but now, are there any options besides Netinstall? I am quite remote to this system, if it is possible to fix without Netinstall, it would be nice. And, if this is impossible, how do I proceed with Netinstall? I am very confused because it booted with the new RouterOS once, and won’t boot after configuration clear. What increases the confusion is that I selected the long-term channel to update (it was named bugfix in the old RouterOS). This router was running RouterOS 6.40.3 until this update, showing no obvious signs of problems.
