RB2011UiAS-2HnD-IN and SPF modules unrecognizable
for my home network I used RB2011UiAS-2HnD-IN for a long time. It is nice device with slow wifi ( max 72 Mbps stable working mode ). Now I have a new toy RB4011iGS+5HacQ2HnD-IN. In the same condition N on 2.4 Ghz works better ( 300 Mbps working mode ).
So I decided to connect both devices with fiber. And the bad new arrived. RB2011UiAS-2HnD-IN cannot recognize any SPF module.
Example of RB4011iGS+5HacQ2HnD-IN
Empty slot:
[admin@MikroTik] > interface ethernet monitor sfp-sfpplus1
                    status: no-link
          auto-negotiation: done
               advertising:
  link-partner-advertising:
        sfp-module-present: n
With SPF-T:
                    status: no-link
               advertising:
        sfp-module-present: yes
               sfp-rx-loss: yes
              sfp-tx-fault: no
                  sfp-type: SFP-or-SFP+
        sfp-connector-type: LC
    sfp-link-length-copper: 100m
           sfp-vendor-name: OEM
    sfp-vendor-part-number: SFP-T
         sfp-vendor-serial: 6C6160622009
    sfp-manufacturing-date: 16-06-22
           eeprom-checksum: good
                    eeprom: 0000: 03 04 07 00 00 00 08 00  00 00 00 01 0d 00 00 00  ........ ........
                            0010: 00 00 64 00 4f 45 4d 20  20 20 20 20 20 20 20 20  ..d.OEM
                            0020: 20 20 20 20 00 00 00 00  53 46 50 2d 54 20 20 20      .... SFP-T
                            0030: 20 20 20 20 20 20 20 20  20 20 20 20 00 00 00 53               ...S
                            0040: 00 00 00 00 36 43 36 31  36 30 36 32 32 30 30 39  ....6C61 60622009
                            0050: 20 20 20 20 31 36 30 36  32 32 20 20 00 00 00 6a      1606 22  ...j
                            0060: 00 00 08 2b 15 bb c2 8c  02 47 c0 01 72 28 24 17  ...+.... .G..r($.
                            0070: 80 79 75 00 00 00 00 00  00 00 00 00 44 7e 8b 92  .yu..... ....D~..
                            0080: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0090: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00a0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00b0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00c0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00d0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00e0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            00f0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
With another SPF:
                    status: no-link
               advertising:
               sfp-rx-loss: yes
              sfp-tx-fault: no
       sfp-link-length-9um: 15000m
           sfp-vendor-name: WTD
    sfp-vendor-part-number: RTXM182-525-C17
       sfp-vendor-revision: 1.0
         sfp-vendor-serial: WHTDCN14321231
    sfp-manufacturing-date: 14-08-22
            sfp-wavelength: 1310nm
           sfp-temperature: 33C
        sfp-supply-voltage: 3.287V
       sfp-tx-bias-current: 14mA
              sfp-tx-power: -5.234dBm
              sfp-rx-power: -44.299dBm
                    eeprom: 0000: 03 04 07 00 00 00 40 00  00 00 00 03 0d 00 0f 96  ......@. ........
                            0010: 00 00 00 00 57 54 44 20  20 20 20 20 20 20 20 20  ....WTD
                            0020: 20 20 20 20 00 00 00 00  52 54 58 4d 31 38 32 2d      .... RTXM182-
                            0030: 35 32 35 2d 43 31 37 20  31 2e 30 20 05 1e 00 0b  525-C17  1.0 ....
                            0040: 00 1a 00 00 57 48 54 44  43 4e 31 34 33 32 31 32  ....WHTD CN143212
                            0050: 33 31 20 20 31 34 30 38  32 32 20 20 58 f0 02 6e  31  1408 22  X..n
                            0060: 41 4c 43 41 54 45 4c 20  33 46 45 32 35 37 37 32  ALCATEL  3FE25772
                            0070: 41 41 30 31 20 56 41 55  49 41 47 55 41 41 41 b3  AA01 VAU IAGUAAA.
                            0080: 64 00 d3 00 5a 00 d8 00  8c a0 75 30 88 b8 79 18  d...Z... ..u0..y.
                            0090: 88 b8 00 00 75 30 00 00  12 9f 07 69 0e ca 09 55  ....u0.. ...i...U
                            00a0: 57 2d 00 58 2b b1 00 b1  00 00 00 00 00 00 00 00  W-.X+... ........
                            00c0: 00 00 00 00 3e e5 69 6e  00 00 00 00 01 00 00 00  ....>.in ........
                            00d0: 01 00 00 00 01 00 00 00  01 00 00 00 00 00 00 ae  ........ ........
                            00e0: 21 e0 80 68 1c 64 0b b4  00 02 00 00 00 00 02 f8  !..h.d.. ........
But inside RB2011UiAS-2HnD-IN
Empty slot:
[admin@MikroTik] > interface ethernet monitor sfp1
                    status: no-link
               advertising:
               sfp-rx-loss: yes
                  sfp-type: (unknown)
                    eeprom: 0000: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0010: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0020: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0030: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0050: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0060: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0070: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
With SPF-T:
                    status: no-link
               advertising:
               sfp-rx-loss: yes
                  sfp-type: (unknown)
With another SPF:
                    status: no-link
               advertising:
               sfp-rx-loss: yes
                  sfp-type: (unknown)
Both use 6.44.3 version. Any idea?
BTW why RB4011iGS+5HacQ2HnD-IN SPF slot is reversed? It is harder to unplug fiber cable.
No news how to fix/debug the problem?
Same problem. how to fix it?
First of all, upgrade RB2011 at least to latest long-term ROS version (at this time 6.48.5, but beware of some issues reported by some users so you may want to go for 6.47.10).
Then get SFP modules know to be compatible with your device. Mikrotik has SFP compatibility list (which includes only MT’s own SFP modules). Some 3rd party vendors offer SFP modules and they claim compatibility with MT.
