RB2011UiAS-2HnD-IN + dual band WiFi?
I basically need to build a RB2011UiAS-2HnD-IN like router but capable of having two WiFi networks (one 2.4ghz and one 5ghz) running at the same time. Is this possible?
If so, which routerboard, mini pci cards, antennas, case and power supply would you recommend?
I need it to have level 5 license being able to support at least 50 active sessions on a RADIUS server.
Thank you,
