I have RB2011UiAS-2HnD-IN setup as adapter (ip 192.168.2.3) connect to another router with IP (192.168.2.1).
behind RB2011UiAS-2HnD-IN is my git server with ip 192.168.4.2; my git server name is gitserver.net.
from another pc (ip 192.168.2.4), I could forward the gitserver.net to 192.168.2.3; but I can not get throw the router RB2011UiAS-2HnD-IN
to be able to connect to 192.168.4.2.
I need some setup on RB2011UiAS-2HnD-IN, any help ?
I bridge all network 192.168.4.1 to 192.168.2.3
Pat
- First sete first router to work as AP.
- Second Mikrotik 2011 set to work as Station Pseudobridge.
- Open the port 80 to port 82 on RB2011 in first router where port 82 is your webserver.
- Port Forward DST.Nat in RB 2011 from port 82 to local IP on your server on portr 80 (default).
- Try to load your external IP.
p.s: set static ip to your server in pool 192.168.88.XXX.
could I forward domain name(gitserver.net) to specific IP on router (Station Pseudobridge) ?
I don’t want to change the port on my server.
if yes, how could i do it ?
thank
I add a nat from wireless interface to the ethernet of my git server with port 80.
but, when i call gitserver.net I go directly to web page of mikrotik router, and not my git server.
any help ?
any service on mikrotik help to forward a domain name to specific ip ?
Patrick
I think what you are trying to do is done with 2 NAT rules. First create rules to NAT your LAN networks to the server and then create rules to dst-nat your public IP.
chain=srcnat action=masquerade protocol=tcp src-address=LAN_SUBNET_IP
dst-port=80
chain=dstnat action=dst-nat to-addresses=SERVER_IP_ADDRESS to-ports=80
protocol=tcp dst-address=PUBLIC_IP_ADDRESS dst-port=80
Please disable www from sevices when you want to redirect to port 80 on your webserver. Www use the same port as usual webserver.
