I tried to: start mikrotik RB2011UiAS-2HnD-IN and the router doesn’t boot. The LCD
remain grey and the USB led remain blue. No beep sound at all.
The router doesn’t reset
I follow all the procedure for over voltage checking and Schottky D2,D6,D4 is
found ok . Voltage drop between Ethernet transformers TR102 is 0,32V,TR100 is
0,32V, TR101 is 0,42V and Termination resistors resistance RJ-45 is 75,1Ohm.
I tried the netinstall procedure without success. No router found. All firewalls
at the host computer were off.
I tried to send the .fwf file via serial and xmodem procedure as it described at
https://wiki.mikrotik.com/wiki/Manual:RouterBOOT without success
Does anyone know a workoaround for this issue.
