Hello all, I own a RB2011UiAS-2HnD-IN, which features a micro USB connector, using the included adaptor I can plug a USB 2.5" hard drive for samba share, the hard drive becomes unstable (weird noises inside the disc)
I think it is related to RB2011UiAS-2HnD-IN not providing 5v 500ma from the usb port, leading to USB hard drive crash. Tried different hard drives, same results.
buying the mikrotik usb 5v power injector may solve the issue but I don’t want that solution.
For the record, it worked flawlessly on my old RB751 which features a regular size USB connector.
Have happened this to anyone? any suggestion/solution?
I guess 500ma is not enough to spin up the hdd. It is known that usb powering is usually very weak on mikrotiks, for running hdd you need external power supply.
Hello, thank you for help, I will try another mikrotik power supply, even some usb usb flash drives become unstable due to lack of power, If I connect a usb hub with external supply it work flawlessly, I was trying to avoid the external supply because I don’t want that much wiring, thank you all
