RB2011UiAS-2HnD
i’m new here so by the way just saying hi to community!
So here is my problem - can’t get more that 220Mbps (local transfer eth2-eth3 - LAN and lets say im good with that it can be hdd-max) and 100Mbps (wan transfer eth1-eth2)
so what i did:
  • eth 1 is wan with dhcp client
  • eth 2 is Lan master with dhcp server
  • eth 3 is Lan slave to 2
    set local address range, dns, nat-src masq, sntp, dhcp pool.
    no firewall, no que, no bridg etc etc straight and easy config its straight as .. well nvm its really only what is needed .
and more of my problem when i use ookla testing or some NOC-site to download something direct to PC its 250Mbps when i connect router its max 100 and most times 80 i connect it again direct its 248-260.
i read most of basic config tutorials, wiki, made full clear of config - started from scratch with easiest mode config.
So please point me where to look where to check, what to do next?
