i recently bought a RB2011UiAS and after booting it up
it seems that there is a problem with the Ethers from (6,7,8,9,10)
they in the win box seem to be working just fine and they are not disabled
but when i connect my PC or other RB Lan cable
still no connectivity??
i check the cables is ok, reset default configuration and upgrade the router to 6.28 and upgraded the routerbourd frimware
but still the same problem
all the Giga ethers from 1 to 5 is working just find but the others is not working.
Is there a soultion to this problem ? could you help me with.
The 100Mbit and 1000Mbit ports are on different switch chips. That means that either some cables connected to 1000Mbit or some cables connected to 100MBit can communicate together but not with each other. To connect those together you will have the bridge them together through software.
Dear
Thank you for your replay
I already know that i have to put the Ethers in Bridge to connect together but
My problem is that these ethers can’t even connect to Pc or any other devices
I’m mean LAN connectivity?
that’s my Problem
So you mean the light on the RB2011 doesn’t turn on and also on the PC side the lights on the ports do not turn on? Windows says “No connectivity” as if no cable is connected? (Red Cross)
Have you tried different cables? And different computers?
