RB2011UiAS-RM and Huawei E3256W
Greetings,
First post, just got my first RB.
I have a Huawei E3256Ws-2 3G USB dongle that I was hoping to use with my Routerboard. It comes up as “HUAWEI Mobile” in the “system resource usb print” listing but there is no port listed so I assume this particular model is not supported.
Is there a way to get it to work?
Thanks in advance!
Have you installed the latest RouterOs? 6.11?
If you go to 'interfaces" see you not a LTE interface?
Yes, running 6.11.
No LTE interface, no port.
I think the usb device is not compatible with routerboard
