Hello, I have one Rb2011uias-rm and I have this problem:
When I Start the device the beeper makes sounds, if I use :beep or any script to play sounds the beeper works OK.
But If I let te device for example 1 day ON the beeper stop working, If I try to play again any sound via :beep in console or via script DONT WORK.
If I restart the device beeper Works OK for a couple of hours (or 1 day).
Model: Rb2011uias-rm
Firmware: 3.24
RouterOS: RouterOS 6.32.1
I think is some software bug.
Anyone have this problem?
No, it’s okay for me (RB2011UiAS-2HnD). I don’t think this is software bug in your case. You can reset configuration and Netinstall RouterOS “from the blank page”, but this is probably all you can do.
plisken
September 16, 2015, 4:26pm
3
Go to “system” “routerboard” “settings” look to “silent boot” are this select?
Many thanks for the replys.
@G2Dolphin
I will try to disable all scripts and try again.
Thanks for the tip using Netinstall (im new with mikrotik)
@plisken
Is not selected
/system routerboard settings> print
baud-rate: 115200
boot-delay: 2s
enter-setup-on: any-key
boot-device: nand-if-fail-then-ethernet
cpu-frequency: 600MHz
boot-protocol: bootp
enable-jumper-reset: yes
force-backup-booter: no
silent-boot: no
plisken
September 21, 2015, 6:25am
5
Try with other RouterOs
For downgrade see on my website.
In dutch but folow the printscreens a made
http://www.wirelessinfo.be/index.php/mikrotik/pages/upgrade
