RB2011UiAS-RM ISP Change How To
Hello Good Day!
I would like to seek help on this. How can I transfer to other ISP by means of radio?
Here are my network given:
both router are in bldg1 and 2 are using RB2011UiAs-RM
Bldg1
ISP1, ISP2 ranging 192.168.100.160-192.168.100.200 (the others are ISP1), Radio (10.0.0.1)
Bldg2
ISP3, ISP4 ranging 192.168.80.160-192.168.80.200 (the others are ISP3) Radio (10.0.0.2)
Im currently in ISP2 and would like to go to ISP4 connection in other building.
Let me know if there are some details I need to provide.Thanks
I read your post twice now and don’t get what you want to achieve.
A basic diagram with addresses and interfaces would be good to see. Probably a compact export of both routers and a more detailed explanation of what you’re trying to do.
Thanks,
-Chris
Hi Chris thanks for your reply.
Im new in networking and would like to learn a lot in this field. Im excitingly challenged on this configuration i would like to happen
there are 2 isp in each buildings.
1 building is using 2 isp same as the other building
what would i like to happen is to connect my pc to the other building using their isp.
please forgive my explanation. what details to be exact would you like me to provide?
