we have just bought a RB2011 can I am trying to configure it with a Virgin SuperHub 2 (BUS_V2.37.13). I have put the SuperHub in modem only mode, and when I plug the ethernet cable into my laptop I get an IP address from the Virgin DHCP server and can connect to the internet.
However, when I plug the ethernet cable into the RB2011, I get a different IP address and I do not have an internet connection. The IP address assigned to the RB2011 ether1 interface is a Virgin one, according to ip-lookup.net.
I have tried setting the IP address to static and entering the same settings that my laptop receives, but this doesn’t work either. I have also tried changing the MAC address to match the SuperHub’s WAN modem address but this results in no connection whatsoever.
Thanks, it appears that the SuperHub is not working with my laptop now, when it’s in modem mode. Looks like it won’t work that way for some reason. I have now turned off Wi-Fi and the DHCP server and have set the IP address as a default gateway on the RB2011.
I now need to set up another SuperHub on another interface but the only available interface seems to be sfp1.
Well there are 10 ports on the router and I want to set up 3 of them as WAN ports with load balancing and use another one to connect to an external switch, assuming this is possible?
I am connecting to the RB2011 via ether5 at the moment so I think I will lose connection to the router when I delete the default config? I think this is the problem I had before, so I am trying to work with the default config.
Or is there another way of connecting to the unit? As far as I know, there is no serial port on the unit (I am not in front of it at the moment) but I am pretty sure it is the same as this on the back:
The front panel just has micro USB, SFP, 5 x gigabit ethernet and 5 x fast ethernet. I believe the USB port is only for external storage/or 3G/4G modem? This post would seem to confirm that, but I am fairly certain there is no serial port on the back of the unit.
Is there another way to connect if I delete the default config?
Thanks, I have got WinBox working on my Mac with Wineskin.
My current config is below. I now have a working internet connection, but how can I configure load-balancing for the second internet connection? Or even test that it is working?
# may/03/2016 14:42:26 by RouterOS 6.35
# software id = XXXXXXXXX
add name=bridge1
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
set [ find default-name=ether3 ] name=WAN3
set [ find default-name=ether4 ] name=ether04
set [ find default-name=ether5 ] name=ether05
set [ find default-name=ether6 ] name=ether06
set [ find default-name=ether7 ] name=ether07
set [ find default-name=ether8 ] name=ether08
set [ find default-name=ether9 ] name=ether09
/ip neighbor discovery
set WAN1 discover=no
set WAN2 discover=no
set WAN3 discover=no
add name=LAN-DHCP ranges=10.0.1.0-10.0.1.199
add name=LAN-SERVERS ranges=10.0.1.200-10.0.1.254
add address-pool=LAN-DHCP interface=bridge1 name=DHCP
add bridge=bridge1 interface=ether05
add bridge=bridge1 interface=ether06
add bridge=bridge1 interface=ether07
add bridge=bridge1 interface=ether08
add bridge=bridge1 interface=ether09
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=sfp1
add bridge=bridge1 interface=ether04
add address=10.0.1.1/24 interface=bridge1 network=10.0.1.0
add address=192.168.10.2/24 interface=WAN1 network=192.168.10.0
add address=192.168.11.2/24 interface=WAN2 network=192.168.11.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=WAN1
set servers=8.8.8.8,8.8.4.4
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add distance=1 gateway=192.168.10.1
add check-gateway=ping distance=1 gateway=WAN1
add distance=2 gateway=WAN2
/ip service
set ssh port=XXXX
/system clock
set time-zone-name=Europe/London
/system routerboard settings
set protected-routerboot=disabled
