We have a new RB2011UiAS setup, with very simple config. Our bandwidth is 300MB, and tests as such if I config. a system directly with the static IP info. However, going through the Tik we never get much more than about 80MB locally and testing with ping speed on the Tik itself. Any thoughts or ideas where to look? Switches are all Gigabit. Thanks in advance!
If you do nat without queues try fasttrack.
Thanks for the response, I have setup fasttrack - will watch and see if any difference.
I think 80MB is too slow. I suspect PPPoE.
Fasttrack would be needed anyway.
The WAN connection is not using PPPoE
