Although something broke on one of the other vlans, I’ve tried this: (I think this is what the config should be like)
Tell me if I’m missing something
I have two master port groups.
[root@rb] > /interface ethernet print
Flags: X - disabled, R - running, S - slave
NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
Fa1 1500 00:1D:60:E2:62:80 enabled none switch2
Fa2 1500 4C:5E:0C:1E:A9:64 enabled none switch2
Fa3 1500 4C:5E:0C:1E:A9:65 enabled Fa2 switch2
Fa4 1500 4C:5E:0C:1E:A9:66 enabled Fa2 switch2
4 S Fa5 1500 4C:5E:0C:1E:A9:67 enabled Fa2 switch2
5 RS Ge1 1500 4C:5E:0C:1E:A9:5E enabled none switch1
6 S Ge2 1500 4C:5E:0C:1E:A9:5F enabled Ge1 switch1
7 S Ge3 1500 4C:5E:0C:1E:A9:60 enabled Ge1 switch1
8 S Ge4 1500 4C:5E:0C:1E:A9:61 enabled Ge1 switch1
9 Ge5 1500 4C:5E:0C:1E:A9:62 enabled none switch1
10 Ge6_FX 1500 4C:5E:0C:1E:A9:5D enabled none switch1
A bridge.
[root@rb] > /interface bridge print
0 R name=“br_sw1_sw2” mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled arp-timeout=auto mac-address=4C:5E:0C:1E:A9:5E protocol-mode=rstp
priority=0x8000 auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
A members of that bridge.
[root@rb] > /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 Fa2 br_sw1_sw2 0x80 10 none
1 Ge1 br_sw1_sw2 0x80 10 none
A member ports of that vlan.
[root@rb] > /interface ethernet switch vlan print
SWITCH VLAN-ID PORTS
2 switch2 12 switch2-cpu
Fa3
Fa5
3 switch1 12 switch1-cpu
Ge1
Ge2
And a port config for vlans.
[root@rb] > /interface ethernet switch port print
Flags: I - invalid
NAME SWITCH VLAN-MODE VLAN-HEADER DEFAULT-VLAN-ID
1 Ge1 switch1 secure always-strip 12
2 Ge2 switch1 disabled leave-as-is auto
7 Fa2 switch2 secure always-strip 11
8 Fa3 switch2 secure add-if-missing 0
11 switch1-cpu switch1 disabled leave-as-is 0
12 switch2-cpu switch2 disabled leave-as-is 0
At current I have no access between Fa3, Ge1 and a vlan-intarface in this 12 vlan
[root@br] > /interface vlan print
NAME MTU ARP VLAN-ID INTERFACE
2 R vlan12 1500 enabled 12 Fa2
Am I missing something?
